- Dec 16, 2013
- 10
So the outer spindle diameter is the same? Wonder why they didn't just use the same spindle...
Yep, the hand wheel was very familiar to me. I grew up playing on a Clausing identical to the one in the attachment. I am looking to purchase the 1236t in 1PH. How do you like yours after using it for a few years now?
I realize I'm responding to something you mentioned in 2019, but I had a mostly useless, academic thought I wanted to run by you
When I read this part of your post, I wondered just how much more rigid would the d1-5 in the g4003g be than a d1-4 in a similar class of machine.
So, the point on the spindle that would be subject to the most deflection stress should be the main spindle bearing behind the spindle, right?
I looked up the specs on 2 similar machines, with each respective spindle. The g4003g and the g4003.
The G4003g has a d1-5 spindle with a 1.57" spindle bore and, according to manual uses a 30212 (60mm Id, or 2.3622" ) bearing. That would make the spindles wall thickness @ the main bearing 0.3961"
The G4003 has a d1-4 spindle, and according to the manual has a 1.417" spindle bore. It also uses the 30212 bearing. That would make the spindle wall thickness @ the main bearing .4725".
So, regardless of the d1-5 spindle mount, the g4003g spindles OD @ the bearing boss is the same as that of the g4003 @ 60mm ( 2.3622"). But the 4003g has a significantly larger bore, and correspondingly less spindle wall thickness.
Taking that into consideration, I wonder just how much more rigid is the g4003g spindle? May even be less rigid, perhaps?
A purely academic thought, since I own neither machine.
Also, I am not sure whether these two examples are representative of D1-4 and D1-5 spindles from other manufacturers and one has to wonder if, in this case, the manufacturer chose a similar part and simply enlarged the bore a bit since the consumer expects a larger spindle bore with a D1-5 machine.
Absolutely correct, I spent a large part of my working life as an engineer on cargo ships. Most of those ships had a workshop that included a lathe, some also had other machines such as mills, one even had a shaper.Jester966, think of it this way. Say you are a machinist on a battle ship, your captain runs aground in choppy seas and bends the prop shaft. The enemy is approaching and you need to turn a new prop shaft pronto! Your lathe was adjusted on land to have no twist in the ways and then bolted to the battle ship. But now you are at sea, the ship is pitching and rolling! What do you do? You turn a perfectly untapered shaft because the movement of the ship, even though it is creating a constantly unlevel lathe, has no affect on your lathe as long as the ways are untwisted. You are promoted, retire with a huge pension and live happily ever after. Think of the plate on the mobile base as the battle ship.
Thanks you and I appreciate your feedback!TK, You have did an exceptional job putting your lathe together, it looks great!
Your documentation in this thread is also exceptional.
Thank You for all your efforts!
Tim
