- Mar 26, 2018
- 8,411
Richard,Some folks slide a coolant hose up the handle or wrap it with rubberized electrical tape or wear leather gloves. I have also had students drill and tap holes in the steel handle so they can put a vertical handle on the scraper handle. Use a round rubber bike steering handle.. Once you put a rubber sanding pad on the wood end and push with your body and not your hands and arms you will feel better. Learrning to scrape especially when the blade is dull or lapped wrong it makes hand scraping a real "pain".
Your video shows the method you use to hand scrape. It's poetry in motion.
Do you have the video available to the forum? in the database?
I know it's copyrighted material so I hope I'm not stepping out of place here.
Lots to learn in the video.
