- Jun 17, 2012
- 2,220
The 40 and 60 amp machines probably used the same torch and the same case. A 60 amp chinese torch will probably do the trick. You'll probably need the larger size torch to fit the everything at the end of the whip inside the torch.Yes there is a schematic inside the case, one side has all the electronics, the other side has discharging the capacitor/input wiring/torch connection & type which says Magnum pct 60 plasma torch
Something just dawned on me that this is a 40, the tag inside the cover calls out a 60 torch, the power cord is a 3 ph 4 wire not using the 4th wire, it is wired for single phase but the tag in the cover shows both hookups, wonder if this is even the right cover?
I robbed the power cord to use on my Lincoln tombstone as it was only about 3' at most.
I'll probably order that torch in a few days and give it a try, Wonder if consumables are readily available state side?
Yes consumables are readily available for those torches stateside. Here's an ebay seller that sells the consumables for the chineese stuff : http://stores.ebay.com/PlasmaDyn-Plasma-Welding-parts?_rdc=1
There are other sellers too. The torch can also be had stateside but you'll probably pay a few bucks more but it will come much quicker. When I had my longevity machine I had bought extra torches and consumables off of e-bay, pretty cheap too. Shop around. Don't buy any consumables yet until you can get your machine fired up...just in case.)
Marcel
