SB 9 Junior
I think I have completed the motor mount. I added some bushings to each end of the pivot shaft to keep the mount assembly from moving side to side when I would manually lift it. Anyway, at this point, subject ot running the lathe for a while, I don't think I need a lifting cam. Actually, the way it is presently set in running position, I don't have to lift the motor assembly to make belts changes. I am getting the proper belt tightness, yet, I am able to slide the belt off the pulleys for belt changes and removal.
