The self contained motor unit does not use the same system with the turn-buckle. It is a little difficult to tell from the pictures, but see the pictures in my 1st post in this thread, and there is no kind of swivel on the bracket. I was thinking I would make tracks for it to slide in and out. For now, I am able to slide the belt off and on, but the tension is not sufficient if i want to take a heavier cut.
I was able to do the repair with pins I threaded in (instead of welding; no welder) across where the tooth would be on my back gear on my 9a. This one has the teeth missing on the bull gear in 2 locations. The more difficult part on the Junior is that one of the areas of the broken teeth has 2 teeth in a row missing.
By the way, I did receive the Bostar qctp, but I used the one from my 9a to try out the Junior. Haven't milled the Bostar mounting bracket to fit yet.
Thanks OT. I appreciate all your input.
