Thanks, OTmachine. I do have a tool post set-up for my SB 9a that I could use interchangeably but with different tool holders; but, that one in the link appears to be a nice set at a reasonable price. Do you have one?
Thanks, silverhawk. I was hoping you would respond. My research on this site has shown you as having a Junior for a while now. I certainly have questions now, particularly with regard to the spindle bearings. On my SB9a, you have to press the spindle on and off; On the Junior, will it just lift out with the whole gear and pulley assembly by removing the bearing caps? There are new machine shop made bearings in it now; but, per the seller, there are no flanges, so he used washers on the front bearing between the spindle flange and the headstock casting. Seems to run well in this configuration as there was no heating of the bearing areas when run for a while. Have not checked the bearing adjustment yet.
However, I do have the old bearings that I was considering using; but it appears that someone put some oil paths in it which may or may not have been a good thing. Also wondering if the old bearings are maybe worn thin; but, they look to be in good condition. Also, are there shims that go where the bearing caps mount to the headstock, like on the SB 9a?
I need to get it up off the ground (my old back and legs won't take too much more bending and stooping). Looking for a bench. In the meantime, here are some photos of the old bearings as well as the washers, one of which is a thrust washer.
