- Oct 29, 2012
- 1,329
Which one? ... never mind, I'm sure there are several.I consider myself "smarter" and more "practical" than an engineer.
I might count myself among them. I'm not a very good communicator. It is a known deficiency. I try hard to express things clearly, and I thought I did a decent job in my first post, but it seems the majority read something between the lines that wasn't supposed to be there. Not totally sure but from context cues I guess it came across as "hi, my name is strantor and I'm an idiot. I've destroyed 15 PTO shafts in the past year and I can't figure out why." Just read the parts in bold, or I can summarize: I'm building a PTO Dynomometer.
I want to make a torqe-sensing PTO shaft for my tractor. I don't want a pony brake dyno or anything similar, I want to measure PTO torque and speed while running actual PTO attachments. To do this I think the simplest way is to measure twist of the PTO shaft. So contrary to the norm, I want the maximum safe amount of twist. This will make my measurement less challenging. I've calculated some values for hollow tube and solid rod, and for my target maximum torque over a 5ft shaft I can get 20+ degrees of twist, but I have no idea if that's safe, or one the verge of turning into a pretzel. Is there any way to figure the maximum safe amount of twist?
To be clear, I'm not wanting a way to measure whether or not my shaft has a permanent deformation of twist. I want my shaft to twist, (as much as possible without permanently deforming) so that I can measure the twist in operation, and turn it into a running torque value. I just want to know how much torque I can put on any given shaft without damaging it or someone or something.
Because.
I have unconventional interests. The torque sensing shaft project is an interesting enough project for me to pursue in and of itself. But, it is a means to an end. My tractor is the lowest HP variant (40HP) of a line of tractors that goes up to 55HP. They are all mechanically identical. Same heads, same pistons, same stroke, same fuel pump, same turbo. The only difference is varying levels of handicap in the ECU. I'm going to hack it and I need a way to quantify my results. Planning to use the PTO generator I'm building as a variable load to put behind this.
