- Feb 15, 2015
- 65
I've never had good luck single point treading. I can get good threads with the correct pitch diameter but they look like they've been chewed out with an axe. My latest attempt was on 12L14 with a brand new carbide threading insert appropriate for the TPI. For scale, the picture is showing a 3/4-16 thread. I was feeding in using the cross slide rather than the compound. I went in with about 8 steps, larger at the beginning, decreasing as I got close to the correct dimension, and a couple of spring passes to final dimension. I run at a pretty low RPM and was feeding towards the headstock as opposed to Joe Pie's revese feed. Anyone have any suggestions on what I may be doing wrong?
