Rollout Wheel (Welding Positioner)
This is not where I had planned to tack it, but the situation called for keeping the assembly clamped closed.
There is some undercut on at least 3 of these tack welds:
I tested that it can go vertical, horizontal or 45°:
Up next is tacking this assembly:
This is next. I covered the spacer because I don’t want to confuse anybody. The spacer that I am using is another part of the kit that does not belong there, so I covered it.
I dipped the tungsten again + minor undercut, lower right:
I am welding this in the fixture because I have to tack in one side, & then pound the other side out square.
You can see in the photo that the near side is flush, & the far side is pushed down a little.
Let’s see if I can pound this straight:
I think I got it:
