- Mar 18, 2011
- 243
Yes, I agree. Also, I would have to measure the compressed size of the split pin to properly size the loose hole on the center piece of the hing where it would have clearance. Initially, I thought of using a 3/16" shoulder bolt with a 10-32 thread and that would work great, but the guy either doesn't want to pay for the more expensive bolts, or he says he does not want the head of the bolt visible. I sippoe I could cut the head off and make a screwdriver slot and still get away with it.I'd be concerned about wear on the moving part of the hinge with a roll pin. The slot or edge of the spiral depending on the type is going to cut the aluminum. A solid smooth pin as you suggested is going to cause less wear.
Greg
I agree too. Now if I go with the dowel or guide pin of 5/32 or 3/16, what is the cheapest option on getting a drill bit or a reamer to do it? Find a .001 sized guide pin and use a standard drill or end mill?I agree with Greg. A dowel in would be a better choice for a hinge type design. Sent from my iPhone using Tapatalk
Thanks,
schemer
