- Mar 18, 2011
- 243
Hi guys,
I have a question on split or roll pin use when the part is made of 6061 aluminum. I found a chart and they show a recommended range for the hole size based on the roll pin size, but I am curious if smaller or larger is the way to go so I don't mess up the parts. This will be used on some hinges I am making for a guy for an old sports car with really light fiberglass doors. The original hinges are made of pot metal and all cracked an probably not fixable. I suggested using shoulder or stripper bolts for the pin but he does not want that because of the look of the head of the bolt. The original had 3/16" pins and for some reason he didn't want to use solid pins?? He wanted to use a 10-32 flat head screw but I told him it would be impossible to find one with a shoulder as they are usually threaded all the way to the top on short sizes. I started on the hinges and made them a little thicker etc but they have to be laid out with the hinge and mounting holes the same locations and distances apart for the doors to line up. Do you see any problems using a 5/32 or 3/16 roll pin for this? I am thinking maybe just get 4 solid pins that are 5/32 x 1-1/4 or 3/16 x 1-1/4 and just doing it like the originals. And lastly, does anybody have a large assortment of solid dowel pins that could sell me a few? Thoughts?
Thanks,
schemer
Thanks,
schemer
