I'm guessing that you have a G4000 or clone. If you run the 60 tooth gear in place of the 120 tooth gear and the 80 tooth gear in the b position, you should get down to .00176"/rev. You may be close to hitting the bushing behind the 80 tooth gear with the 127 tooth gear. If you have interference, swap the 120 tooth gear for the 127tooth gear and you should be good. That would increase the feed rate to .00186/rev.
Excellent,
Thank you !!
