- Nov 25, 2015
- 8,287
I need to know how I need to prep an aluminum sleeve to go into an aluminum pulley. The previous owner of the mill let the bearing wear out the bore. They used a screwdriver on the top to try to capture the bearing. I would have dimpled the inside of the bore to create a tight fit. Too late the bearing ate the bore out. I went to check the part with the old bearing and it's so loose I need to fix it. I made a slug last night to fit the bore (after cleaning up the bore). I planned on using permanent locktite to glue it in, then rebore for the bearing. But now I'm wondering if it will sieze while pressing it in. I think it might. What would you do to prevent it from siezing, or will the locktite act like anti sieze during the press in. Al to Al is usually a bad thing..
