- Apr 20, 2014
- 34
Bear with me as this is my first mill. I got it finally all settled in and cleaned up. Thought I would start firing up the mill so it can slowly start to work. The problem is the main green power button doesn't work. Put the switch in mill/drill or tapping. Nothing. The DRO, quill DRO and blue RPM display does go on. But that's it. Can't notice a loose cable or anything abnormal. Looked into the enclosure and the fuses are ok. Don't know if I'm missing or doing something wrong but I can't get the green power button to work. Attached the X power feed and it also doesn't turn on.
Also does anybody know where I can buy a replacement drawbar as the one that came with the mill is threaded so badly I can barely get the nut to move safely as it's crooked as hell. I've also noticed my drawbar barely sticks out from the top as opposed all the ones I have seen that go up several inches. Had to remove the collet pin stop as I could not get one collet to get through if my life depended on it. However the supplied collet with the drill chuck did work.Everything else so far looks to be ok. I'm sure I'll eventually have more questions.
Since it's WK I won't be able to talk to Matt so I'll have to wait till Monday but in the meantime I'm slightly frustrated. It's like telling a kid in a candy store he can't have any. LOL
TIA, Max
TIA, Max
