- Feb 27, 2014
- 2,130
OK, I looked at the user manual for the PMDX-126 and this is what it says regarding power (found on p8 of the PMDX-126 Revision C users Manual, Document revision 1.9 downloadable from the PMDX site"
"If you are using an Ethernet SmoothStepper (ESS), be aware that the PMDX can supply enough power only if the ESS is the only device drawing power from the PMDX-126. If you plan to use the PMDX-107 [...] or any other device that draws power from J1, J2, J3, J4, J5, J6 or J7 then the ESS MUST be powered from an external power supply"
