- Jun 12, 2014
- 4,819
The 1340GT is a nice balance between size, weight and quality for what you are looking for. There are smaller high speed lathes, some people will use use these as a backup for very small projects. I used a 5C collet system on my 1340GT and did some very small work and for finishing work would run the lathe at high speed for polishing. Even with carbide tooling I didn't need high turning speed above 1600 RPM. The D1-4 machines will handle smalls and also larger turning projects very well, the fit and finish on these Taiwanese machines are very good at the price point. On the belting, if running a VFD I would use a single fixed belt position, there is no real need to switch the belt positions otherwise. The stock motor works well with a VFD even though it is not inverter rated. A few 1340GT owners have switched the stock motors out for 2Hp TENV inverter/vector motors, I usually run these to 125 Hz using a 2.3-2.5" motor pulley. These motors have an upper maximum frequency limit of around 200 Hz, the vector type motors are designed to only run off of a VFD.
I would go with the 1340GT which has hardened gears vs. the 1236GT. At this price point I do not have any other suggestions for lathes, I would not consider the SB lathe line which I feel is overpriced for what you get. The 1440GT is going to cost another 3K, would give you a bigger working range with the larger spindle bore. All of these lathe should be fine to run to 2000 RPM on a regular basis and intermittent under 2500 RPM.
