There are many factors that limit the upper speed range, I would be concerned about using the norton gearbox at high speed, you also have limitations of the internal rotating gears and bearings in the headstock. My ERL-1340 in the gear head (splash lube) version goes to 2500 RPM, and the factory VFD version is rated to 3000 RPM. But the factory VFD version only has a 2 speed head, vs. 8 speeds so a lot less rotating mass. With the 1340GT I do not foresee an issue of short periods with speeds on the in the 2000-2500 RPM range but not for extended time. You would need to use a high grade oil with good anti foaming properties, there are also issues of oil drag and shear at the higher speeds. I would monitor the bearing temperatures and make sure the machine is broken in before extending the upper end speed range. In the VFD builds with the stock motor, I often suggest flipping the motor pulley so you are running from the large motor pulley to the large headstock pulley, ~1.5:1 pulley ratio. This requires a slightly longer belt, I have seen both BX26 and BX27 used but varies by belt manufacturer. With the stock motor set pushing it to 100 Hz would be in the neighbor hood of 2000 RPM, 110 Hz would be 2200 RPM. Alternative is if you are primarily doing high speed work is to just run the belt position in the stock high speed belt setting which is close to a 1:1 drive ratio with a maximum motor speed of 80 Hz would give you 2,400 RPM.
