Pipe Welding on Steel
I will be grinding my mistakes after each level.
It took me all the way around the pipe before I think I got the settings correct for my 3/32” el cheapo 6010: 52A, 65% DIG. My owner’s manual says to run 6010 at 65% DIG.
I’m happy with what is going on there at 12 o’clock.
For the time being I’m only working from 10:30 to 1:30 o’clock even though the 6010 is very well behaved going downhill.
I am finding mostly everything about this to be considerably difficult. I was practically in tears just trying to get it in to position to tack weld.
This was the ONLY thing that I found to work. I keep it in the press when I put in the tech welds.
The second day of this went as follows:
(1) more trouble than expected to get it tacked, and even then the pipes were not perfectly aligned nor were the gaps consistent,
(2) I did come to see how the 6010 root goes in (settings dialed, go as hot and fast as you can + as deep as possible within reason, don’t leave behind any holes),
(3) I had to adjust the current for ambient temperature pipe vs. heated up pipe, and also adjust the current for different gap widths,
(4) hot pass (7018, of course) was the easiest because there is nowhere to blow a hole & little chance of undercut,
(5) last passes entail (a) making sure to weld in a straight line, (b) planning how it will all end so that the end result doesn’t stick up too much, (c) a lot of tie-ins, (d) minding where the arc strikes are, and (e) danger of undercut.
I did not try 7018 vertical up all day. I was having more than enough trouble working around 12 o’clock.
At one point, I decided to use the lathe to machine down the root passes for the hot passes. I found out quickly that my 8” 3J scroll chuck has much less clamping power than my 12” 4J independent (I need to clamp on the inside of the pipe).
Also, I had the compound set to a 37 1/2° (bevel chamfer) angle. I thought I could do a little bit of turning (actually “grooving”) on some 4” pipe with the compound set at that angle. I didn’t think ahead and the rotating pipe came in and took a small (kidney bean size) bite out of the compound on my new lathe. This is the sort of thing that you would expect to see in a high school shop class.
I taught stick and tig pipe welding to pipe trades apprentices for 22 years. Some things to consider if you are interested?
Do you happen to be in the Bay Area?
I am going to get all of pipe welding down (to include even oxyacetylene, but I don’t know about FCAW) so post everything you are willing to post. Any and all help would be greatly appreciated. I for one will read and learn everything that you post.
Maybe this thread will end up being super long because I am very interested in SMAW, GTAW and GMAW on steel pipe in all positions! I understand that this will take a lot of time, effort and frustration.
Not in the bay area, Minnesota. First off let me tell you how it happens "on the job". Your set up with gap and land looks fine, you have surely found out by now that pipe is not round! If your coupons both come from the same length of pipe it makes it easy to line them up and deal with ovality, otherwise rotate them to get your best fit - up.
On schedule #40 pipe the root pass is done with 1/8" 6010, not 3/32". never a downhill root on pressure piping 12" diameter or less always uphill, less chance of slag inclusions.
The hot pass will either be done with, depending on the prescribed weld procedure, 1/8" 6010 or 3/32" 7018, both will be run uphill.
The cover pass will be run with, also depending on the prescribed procedure, 1/8" 6010 or #/32" 7018, both will be uphill as well.
The reason for 1/8" 6010 and 3/32" 7018 is that both can be run at the same amperage (about 90 for starters). You don't want to have to jump out of the ditch and run back to your welder to adjust amps between the root and hot pass and cover pass. Minor amperage adjustments are accomplished by varying travel speed and arc length, you will get used to it.
Just a couple of observations. You have to hurry so fast with your root because you are using 3/32", 1/8" will deposit more filler material at a slower travel speed. You are "outclassed" by 1/8'' 7018 in a small bevel. The hot pass should be level with the parent metal and the top edges of the bevel should be visible and not eroded. When doing the cover pass the electrode should hesitate centered on the edge of the bevel long enough to fill the puddle and then move one electrode diameter uphill and hesitate on the opposite bevel.
I am not just picking these rod diameters out of thin air, they are the industry standard and will be the same for every test. Stringer beads will be used on horizontal welds for the cover pass. You have to have patience and walk before you can run. I wish I could spent a few hours with you in a welding booth.
