- Feb 21, 2022
- 779
Good point, the wear on the top of the blade is a true indication of where the the cutting is done. No visible wear is seen on relieved sides as they don't touch the sides of a wider groove.Parting blade cuts on the face in normal operations. When cutting straight in you have no side pressures. You swarf will be as thick as the infeed till it breaks off.
When looking at the parting blade what gets dull. The face top edge not the sides, and I e seen some carbide parting inserts with side relief no way for sides to touch.
Wear can be seen on the corners though, this is from the depth of cut which is the feed per rev. This indicates clearly that the cutting is also performed on the sides, but only on a small distance from the cutting face = to the feed per rev.
