- Dec 21, 2018
- 1,829
Looking at an insert they almost all have some radius on the corners. The radius reduces the area that is in essence torn off. The point where the metal fails. Is that torn area then burnished to create the beautiful finish we see? I use HSS parting blades that I either eyeball sharpen, lazy method, or more precisely grind on the tool grinder. Even though right off the grinder these have "perfectly square corners", so the sides would not be cutting and only a torn chip would be produced the thickness of the feed, almost instantly a corner radius is worn on to the tool. This is because an absolute sharp corner has little material supporting it. So we now have a form tool with a radius corner with progressive shear cutting until the metal fails and some tearing occurs. The wiping action of the progressively thinner cut is therefore going to burnish the surface a little bit in the torn area. This produces a flowing of the metal much like using a sharpening steel on a knife. SWAG System!
All this is merely a bit of mental gymnastics. If I manage to get an acceptable cut I'm happy and go on to try and limit the nextmistake learning opportunity.
