- Dec 27, 2014
- 4,060
leading face of the tool ) will never shear the sides of a groove,
You don't suppose the ends of the leading edge cut to the ends, do you. Well, they do, whether you call it cutting on the side or the face.
Don't forget, the chip has a thickness equal to the feed per rev. This creates a 3 sided shear requirement which is the blade width plus the feed per rev per side. So yes, the blade shears at the front and also has to shear at the sides.You don't suppose the ends of the leading edge cut to the ends, do you. Well, they do, whether you call it cutting on the side or the face.
Never seen big guys like myself eat pizza, have you? One slice. Fold over. Nice triangle that doesn't drop the good parts.For example:
Is it possible to cut a slice of pizza with one cut? - No.. - two sides of the triangle need to be cut to remove the slice from the disc.
Does anyone believe that a parting tool only cuts on the leading face.
There is a lot of discussion on this subject at the moment.
One opinion believes that only the face of the tool cuts when plunging in.
The other opinion is that the face and edges cut, even if relieved.
Just to clarify. The parting tool is a dovetail shape. Square at the face and relieved sides.If the parting tool is normal (90º) to the work, then only the face cuts--the sides are present to hold the face from vibrating.
If the tool is properly setup in the tool holder, only the face cuts.
If the tool is not set normal, all sorts of strange effects may be encountered.
I'll agree, as long as the beer holds out. But this very much reminds me of a serious debate about the number of angels that will fit on the head of a pin.No top rake, completely flat to keep thing simple and not introduce any more variables..
I agree; if the sides of the tool are not cutting & the material is 'pulled off ' in parting and grooving operations, a poor finish is probable.
If a good finish is acheived on the walls of the groove, would you agree that the sides of the tool are cutting?
