- Jan 7, 2016
- 3,279
Totally fine @7milesup!
It’s all learning for me. And I was frankly surprised that Parker Majestic calls for #2 every where on my machine. Maybe though the higher tack factor of the #2 is to keep the oil stuck on the vertical lead screw in the column?
Very possible Dave. I do find it surprising that your manual calls for Vactra #2 everywhere yet it does make perfect sense on the vertical ways. I just went and looked at my manual and it calls for "a suitable grease" be applied "as required". I would say that is a rather broad requirement. I guess that one of my go-to's, Super Lube, is what I will be using.
I do know that the oilers and oil passages were plugged with sludge, so I am glad that I pulled this thing apart to check it and clean it up. Overall, the machine is in good shape, but the lubrication was suspect.
Also, my longitudinal movement is effected by a cogged timing belt vis a vis your stainless metal straps. It could use a new one, although it is surprisingly good shape for its age. There was a number on the belt but I thought to myself, what are the chances of finding one. Turns out, it is a very common timing belt for cars. I have two open box ones coming from eBay. $10 for two plus $10 for shipping. I guess I am set for life on that end.
