- Feb 1, 2015
- 9,645
Running into the DIY to pick up fresh cement isn't an answer for me. It is a 40 mile round trip. Case in point, I was replacing an outside faucet with a freeze proof faucet. In trying to break the galvanized pipe connections, I managed break the CPVC pipe upstream from the shutoff valve and flood the basement before shutting the main supply. After dealing with the flood, I then had to repair the damage. This consisted of replacing the damaged section and while I was at it, installing the new faucet but I didn't have any usable cement so I had to make the run. That resulted in adding an extra hour to the job during which time, we had no water. I try to have basic plumbing and electrical supplies on hand to deal with such issues as they arise.
The solvent used in PVC cements has a high vapor pressure. If there is any mechanism for escape, it will continue to evaporate until the partial pressure of the solvent in the air outside the can equals the vapor pressure. Flooding with an inert gas won't stop the process. You have to stop the leak.
I had a similar problem with water based wood fillers. The plastic squeeze tubes would dry out despite my best efforts. I started storing them in a sealed Mason jar with an ounce or two of water in the jar and that solved the problem.
Polyurethane varnish will polymerize when in contact with oxygen in the air. I tried flooding partially used containers with argon, with CO2, and with propane with little success. The gases will dissolve into the polyurethane, creating a partial vacuum and the most minute leak will draw in air. The solution there was to decant the urethane into smaller containers, filling them completely to exclude any air. . I keep a supply of glass jars on hand ranging in size from 1/2 gallon down to a few ounces and when I have finished with a particular project, I decant the remainder into a smaller jar. They will keep for years that way.
Throwing containers in the freezer or refrigerator (for water based will slow down any chemical reaction and I use that for short term preservation as when I am applying multiple coats over a period of several days. To preserve brushes, I wrap them tightly in polyethylene film and chill them down. When I need to use them, I pull them out and let them come to room temperature before unwrapping and they're ready to go.
