- Feb 1, 2015
- 9,645
For PVC/ABS cement, it is simply solvent evaporation.Good idea with the foil. Need to make sure there are no creases and it's smooth, but should form a metal to glass seal with the seal pressing it into place. Wasn't sure of the hardening mechanism, if was simply solvent evaporation or not.
My RTV tubes always seem to harden in the neck, by the cap, once the metal seal has been broken. Sometimes I can save them, sometimes they stiffen enough that it just isn't worth it. I had some red O2 safe high temp RTV that I used to seal a stubborn turbo exhaust system and there was some left over. But when I tried to use it again, it was no good. Cost me a week, because I had to order some more, since it wasn't locally stocked. Think I eventually redid parts of the exhaust by cutting off the too thin flanges and TIG welding on stainless flanges and using special clamps to hold the flanges together. That held up well, never leaked again and is easy to take apart if required.
the old RTV cures with moisture. Storing tubes in glass containers with a silica gel desiccant will slow the process. I'm not sure what the process is for the newer RTV's like the Permatex gasket cements though.
The cyanoacrylate adhesives also cure with moisture (technically, the OH- ion). I keep them in a glass jar with desiccant once opened. Polyurethane glue is another that cures with moisture.
