My roll around has locking wheels but I don't use them because it weighs 400# it don't move
The attachment of the post to the cast iron table in Bobs stand above looks scary , hope he's careful with that .
It welded more like cast steel than cast iron. Of course without a metallurgical analysis I can't convince anybody of that. LOL. The steel tube is actually wedged between the webs on the bottom of the table, and then welded up everywhere the stinger would reach. In order to break loose it would take multiple simultaneous failures.
I would suggest attach the stand to something more solid, you don't want your bench grinder moving at all when using it.Especially with the open wheel, it can grab you.
Have you seen a commercial grinder stand? They are light weight flimsy contraptions that you have to put your foot on if you lean into the grinder even a little bit. If you bolt it to the floor with a some redheads and drill it and bolt it hard once you find your height its ok, but that doesn't work out very well in a home shop or even some production shops where space is at a premium for some projects.
Full of concrete as it is now it doesn't move unless I grab it and tilt it. Mass makes a difference. I would have liked a little more mass, but that 16" wheel off one of my 3/4 ton work trucks was the biggest one I had. Well, I do have some 17" wheels, but they are still on the trucks. LOL. It may lighten up a little as the concrete continues to cure, but it felt like about 200 lbs when I had to turn it back over after welding some rebar in the bottom and finished filling it with concrete.
A concrete filled wheel base is not a new concept. I've seen them that way in more than one garage or farm shop over the years. Most just used a large pickup truck wheel like I did. A few used larger wheels, but they were more in the way.
I'm planning a 2x72 grinder build (* because its the hot fad right now) and I'll probably use a concrete filled wheel as a base for that too. (I have three more of those wheels and wheels are cheap at the scrappers if you make nice with them.)
* Actually, as I see the 2x72s get used for more than just knife making I can see some real utility there. I know even since I got my little 1x30 bench sander I use my bench grinders a lot less than I used to.
