- Jul 30, 2017
- 476
I am betting that that original plate is FotoFoil. The small text in the warning area is to fine for screening and way to small for vinyl. The red caution area could have been screen printed on. Fotofoil is an aluminum sheet that is black (or any color) anodized, and then a photo sensitive coating is applied, You use a contact process with a light source, (bright sunlight work great) to expose the sheet and then the "picture" is developed and the plate put into a etchant to remove the anodizing and expose the bare aluminum below. Fotofoil is available in up to .032 thickness you could then hand stamp in the DATE just like the original.
Then if you really want it to last, take it to an auto body shop and get it clear coated. Because it is so small they might even do it for near free as they have more clear than this left over from every job, as long as you are not in a hurry and they can fit it in when they have the oppertunity.
Thanks for heads up on this...
