- Nov 25, 2015
- 8,392
obviously not a good reader. Amazing. But you are trying to prove you are right.. and I am not going to let you have it.This is the difference between lubricating oil and hydraulic oil. As I have stated previously, they are NOT the same.
Mobil DTE Oil Light (Premium Performance Circulating Lubricants)
Products
The Mobil DTE™ Oil Named Series of lubricants are premium performance circulating lubricants designed for applications including steam and hydro turbine sets and other systems where long lubricant service life is required.www.mobil.com
Mobil DTE 24 (Hydraulic Oil)
Products
Mobil DTE™ 20 Series oils are supreme performance anti-wear hydraulic oils designed to satisfy a wide range of hydraulic equipment requirementswww.mobil.com
Read the product sheets.. I won't be seeing your responses.. IGNORE
