so according to the mobil web site it is a hydraulic oil, it is used for both turbine and hydraulic.Woodchucker, Mobil DTE oil light is NOT a hydraulic oil. It is a turbine oil and is designed for bearings and gearboxes NOT hydraulic systems.
Being in this business through the rough years I have used generic hydraulic oil in headstocks, gearboxes and much more.
I have it found it specified by many manufactures in aprons and slides where it performed as a gearbox lubricant as well as a way lube, many of the same machines use it in the headstock.
I don't believe that a hobby user would ever know the difference, I never had a problem with using it.
I have seen problems using way oil in some hydraulic systems, apparently due to the tactifier
In commercial hydro powered mowers.. the Hydro fluid used is Mobile 1 20W-50 motor oil..so according to the mobil web site it is a hydraulic oil, it is used for both turbine and hydraulic.
my jug says hydraulic oil... so I will argue with you. McMaster also lists it as https://www.mcmaster.com/mobil-dte-24-oil/Products
The Mobil DTE™ Oil Named Series of lubricants are premium performance circulating lubricants designed for applications including steam and hydro turbine sets and other systems where long lubricant service life is required.www.mobil.com
And so does this: https://www.amazon.com/Mobil-DTE-24-Hydraulic-Oil/dp/B06XCBZRX2/ref=sr_1_4?crid=3KQXY7UPIV6XD&keywords=mobil+dte+24&qid=1650054392&sprefix=mobil+dte+24,aps,92&sr=8-4
so given that, you may be right... BUT I AM RIGHT TOO.
Applications
The Mobil DTE Oil Named Series of lubricants are premium performance circulating lubricants designed for applications where long lubricant service life is required. Specific applications include:
• Land-based and marine steam turbine, hydro turbine and some gas turbine circulation systems, including pumps, valves and other ancillary equipment
• Continuous service in plain and roller bearings and parallel shaft gearing
• Turbines with oil supplied by splash, bath, ring oiling or other mechanical means
• Moderate severity hydraulic pumps
Motor oil is very bad to use in machine headstocks and such.In commercial hydro powered mowers.. the Hydro fluid used is Mobile 1 20W-50 motor oil..
yes i know.. but it was only an example in jest.. since there was the mention of the broadness of the term " hydrolic oil" cuz that is what they call it when it comes to the hydros in the mowers.. the hydros is what powers the mower forward and backwards.Motor oil is very bad to use in machine headstocks and such.
What is the filter change interval ?yes i know.. but it was only an example in jest.. since there was the mention of the broadness of the term " hydrolic oil" cuz that is what they call it when it comes to the hydros in the mowers.. the hydros is what powers the mower forward and backwards.
