I just purchased a WW II vintage 10-R. The story that came with it is that it was purchased by a dentist after the war and he had it for some time. I bought it from a guy who got it at the estate sale along with a bunch of other stuff. Apparently, the dentist went through the SB catalog and ordered one of almost everything that might go with the lathe and much of it is still in the original packaging. Included in the accessories are: tool post grinder with wheels, 4 jaw Simmons chuck, 3 jaw Cushman chuck, 1/2" Jacobs chuck, Collet drawbar and nose piece and 25 SB collets all in the original Bakelite tubes in the original SB set boxes (unused as far as I can tell), a very nice tailstock mounted adjustable boring bar, about ten assorted armstrong tool holders including some odd boring bar holders and a Williams thread cutter with an interesting "indexable" cutter, SB tool post mounted boring bar holder, SB diamond wheel dresser with the special fixtures for setting up the TPG, SB adjustable stop for the cross slide, about 2 cups of cutting tools, between centers boring bar and a bunch of other miscellanea. It experienced a tip over at some point and there was some damage to the front side handles which had been repaired to a point of functionality, but only just. I have started disassembly and I am pretty encouraged by the condition under 70+ years of petrified oil, dust and grime. Most of the frosting is still on the ways and cross slide. There is certainly part of the ways where the frosting is gone, but, while I can see the wear area, I cannot detect it with my fingernail Very little evidence of compound/chuck crashes. Screws are reasonably tight. I'm cleaning up the apron now and all the guts look like new once you get through the crud. I'm inclined to leave it together and just flush it out well. So far, I can see no pressing reason to take it all apart since I can see nothing that needs help. This will also avoid dealing with the spider's web of wicking strings that go all around the insides. This will be a pretty comprehensive refresh, but I see little value in taking everything apart just for the sake of taking it apart. OPINIONS???
The machine is equipped with vintage GE 1/2 HP 110V motor (same as my 9"SB). Is it worth upgrading this to something a bit bigger while I have every thing apart. I think I may have a 3/4 hp lying around and maybe a 1.5 as well. The drive belt is done (it may be the one it came with) so that will have to be replaced. Any recommended sources of belts. I'll try to post some pics at some point. Naturally, my wife's camera decided to expire in the middle of the first photo shoot so I'll have to deal with that to show any in-progress pics. Thanks for any comments.
ET
ET
