Anyone have a good set of insert tools to suggest. I have been using my PM1030 for almost two years now and been getting by on my Anytime tools insert set. But I want to step up my insert tool game, now that I feel comfortable with not breaking a tool every time I use it
. I saw that shooter was able to use negative rake tools which has me thinking of WNMG, as I begin venturing into steel more. I was also looking at VNMG styile tools. or anything that could let me get closer to the shoulders than a TCMT can. I bought a kennametal tool holder on ebay 5/8" shank with a Shars xl shank but you cannot get it to go low enough to get the tool to go to the center line so want to give the warning to those looking at getting bigger shanked tools.
Glad you aren't breaking tools all the time. I did that a lot too in the beginning. Its nice to feel confident enough to get some nicer tooling because it will last more than 15 minutes. Here are the insert tools I use most on my lathe.
1. This is a CCMT 0602 turning tool holder. I made this one because I could find the inserts online for rediculously cheap. I can usually get them for $5-$8 for 10 inserts and I get 1 set specifically for steels and 1 set for aluminum. I will be remaking this one with the right thread to use the correct insert screw which should make it even tougher. The aluminum specific inserts can take tiny cuts (like .0005) and leave a fantastic finish.
2. These are DCMT 0702 inserts. Same deal as above, I got them because I can find the inserts cheap and I made the holders. These are excellent for getting into tight spaces while profiling. I have used them for roughing before just to see if they can handle it, but I have better tools for roughing.
3. This is the WNMG tool you were talking about. It is the only negative rake tool I have tried. I got them on ebay for $12 for a pack of 10 and they are fantastic. I am still on the first insert and have only indexed to 3 of the 6 sides. I use this one for roughing 12L14 mostly because it can take a .1" (.2" off diameter) cut and make a great chip. I have trouble getting it to chip well in aluminum though and in some other steels, it doesn't like to make chips. I probably don't have the horsepower to get it deep enough and run hard enough to make chips in those steels. It is also in a home made holder. I will be making another 2 holders, one in steel with a proper clamp and another that is much smaller for my micro lathe. A cool thing about this insert is that it will make tight and tiny chips with 12L14 while cutting only .005" deep.
4. These are store bough CCMT 0602 boring bars. I got these recently for my birthday for $25 on amazon. They came with 10 inserts as well. I should have gotten these 2 years ago when I got the lathe. I have been using brazed carbide boring bars and they are honestly garbage. They were $15 I think and for $10 more, these blow them away. I was making some air cylinder chambers which needed a ton of aluminum to be removed and the big boring bar knocked it out of the park. I was cutting .06" (.12" off the diameter) at 1000 RPM at the highest feed rate .01"/rev and it was just dropping the chips right out and they were perfect little Cs. At the widest point, the machine was removing 5 cuin/min!
5. This is also a new one, its a MGEHR 1212-2 grooving/parting tool holder. It can be used for parting, but only up to about 1" in diameter (or something with .5" walls). I have only used it a handful of times so far but it has done a great job for me. It was $19 for the tool and 10 inserts.
6. These are the tools I have had the longest and used the most. They are the common 3/8" triangle insert tools. I have had these since I got the lathe in August 2015. I have used them enough to burn out 15 inserts and they last a pretty long time. I will admit though that I went through 6 inserts in a 4 day period doing a rush job with 304 stainless and I was pushing them way harder than I should have been. I was running facing 1.25" stainless parts at 1250 RPM and .05" DOC. It was about 400 SFM which a US made insert may have been able to handle, but the cheap inserts only lasted about 3 parts per edge. I had to face 72 of them to shorten between .4 and .6" each. I also love using these on other steels and aluminums because they make fanstastic chips. I got new inserts for them that were $12 for 10 inserts and each one lasts a while (except when pushing them too hard in stainless because you have a very short window to make the parts and its worth burning up a bunch of inserts to save time).
Those are the ones I use most. I have yet to try any threading inserts, but I would like to sometime in the future. I have also had my eye out for some CNMG 432 inserts. I think the lathe can handle those, but I am not sure. I have my eye out for large insert lots on ebay for a bunch of inserts I can make holders for.
Here are the links for the tools and inserts I mentioned above.
1.
https://www.ebay.com/itm/10pcs-CCGT...107604&hash=item41c7c1a49d:g:jXwAAOSwjKFZW2iZ
1.
https://www.ebay.com/itm/10x-Gold-C...771753?hash=item2cbf1ae4a9:g:IQ8AAOSw42JZD--y
2.
https://www.ebay.com/itm/10Pcs-DCMT...398798&hash=item4b1611eada:g:UFsAAOSwo4pYmJkS
3. These are similar, but I don't think they are exactly the same. They are also a tad more expensive than the ones I got.
https://www.ebay.com/itm/10-PCS-EUR...354457?hash=item212e477019:g:~7oAAOSwhvFZB7fT
4.
https://www.amazon.com/gp/product/B076J9KXF5/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
5.
https://www.ebay.com/itm/MGEHR-1212...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
6.
https://www.ebay.com/itm/10X-TCMT11...755676?hash=item25d3c5f45c:g:NcAAAOSw3utY6Hmu
I know most of the ones I use are cheap Chinese inserts, but I have had good luck with them and they have served me well. I would buy name brand ones, but its tough to justify them for the work I do. Typically, each name brand insert costs as much as 5 to 10 Chinese inserts, and it has taken me 2 years to go through 1 box of Chinese inserts.
I hope that helps!
