- Jun 7, 2013
- 10,406
Machinery at sea need not be "level", but do need to be in alignment, that is, not twisted or otherwise distorted.
The exception to the statement that level does not matter so long as both ends of the lathe are in the same plane is with lathes that have three or more sets of legs, common on longer machines; in order to "level" them as a practical matter one must have them level in both directions to ensure that the ways are not high or low in their length, in the case of a very long machine, like an ocean wave, although, machines in this class can be "leveled" by a laser, I saw a large lathe, 16 ft. swing and over 100 ft. between centers that was leveled by conventional means and failed to deliver work of sufficient precision; after laser leveling it preformed satisfactorily.Folks have been mangling the English language (or any language for that matter) since language was invented.
It might be more accurate to use the word 'truing' when describing lathe adjustments. The bed doesn't have to be level per se, but the headstock end of the bed needs to be on the same plane as the tailstock, front to back, to remove twist. Left to right is a don't care.
You could mount your lathe to the side of your house if you wanted to, as long as the bed is twist free. But if you do, I want pics!
I have a transit my dad used to use for leveling long lathe beds. He used to level deep hole trepanning machines, which some of them had bed lengths of over 120 foot in length. Most were in the 40 to 60 feet in length. A transit can get a bed level level within a couple of thousandths in ten feet under the right conditions. As mentioned, lasers are more common to use. You still have a margin of error with either method used as well as how stable of an foundation you have for the machine.The exception to the statement that level does not matter so long as both ends of the lathe are in the same plane is with lathes that have three or more sets of legs, common on longer machines; in order to "level" them as a practical matter one must have them level in both directions to ensure that the ways are not high or low in their length, in the case of a very long machine, like an ocean wave, although, machines in this class can be "leveled" by a laser, I saw a large lathe, 16 ft. swing and over 100 ft. between centers that was leveled by conventional means and failed to deliver work of sufficient precision; after laser leveling it preformed satisfactorily.
The lathe that I mentioned was set for deep trepanning; had a bunch of big steady rests and high pressure coolant system and had two carriages that the operator rode on with control panels; all its functions had been converted to CNC so the operator could control everything from either carriage; it had a power tailstock mover and powered tailstock quill; It was used on one job, that of machining giant "pins" that were seismic features of the new Bay Bridge in San Francisco Bay.I have a transit my dad used to use for leveling long lathe beds. He used to level deep hole trepanning machines, which some of them had bed lengths of over 120 foot in length. Most were in the 40 to 60 feet in length. A transit can get a bed level level within a couple of thousandths in ten feet under the right conditions. As mentioned, lasers are more common to use. You still have a margin of error with either method used as well as how stable of an foundation you have for the machine.
I've seen pictures of a couple of the one's you are talking about. They are monsters and hugh! I one's we dealt with back then were set up to drill a maximum of- 4-3/4 hole size. Most were set up to drill about 3" ID x 32 foot deep from both directions at the same time. Any chance of sharing any pictures of them?
