- May 4, 2015
- 3,583
Out of a China lathe , what do you really expect , we all want a top notch part when we make them . But a lot of it is the machinist , not the machine.
If you get it level then what? If your tailstock or head stock is not aligned. Do you reset everything . I agree the lathe should be level but to what extent .007 in 40" . Should not stop the lathe from turning out good parts accurately. I'd Ck the alignment over the bit of level it's off. But I'm a hobbiest now not working for NASA so my tolerances aren't that critical. The others have also stated the weather , the earth are always moving . Good one day may not be better then yesterday. It will change not many places bolt them down , most concrete pads are tapered for water run off , my garage is sloped 2" in 20' , yet the apron is 2" in 10' . When my compressor wasn't piped outside it would run all the way to the street. How to help change just try totally loose the anchors and let the lathe regain its shape. It will move on its own , if you try forcing it I'd bet money it will crack or bust.
