- Dec 25, 2011
- 10,512
OK.
The closer adapter usually looks somewhat like a short MT reducer sleeve but with a flange on the large end, and no drive tang. Inside fits the collet type that it was made for. Typically the bore from the small end to close to the large end is cylindrical and has a short anti-rotate peg inside near the small end that fits the keyway on the OD of the collet. At the large end is a short female taper typically between about 11 and 17 degrees each side.
