- Nov 16, 2012
- 5,596
Glad to hear things went well.
Yes, when you start a cut in the middle of a shaft, it does not dig-in right away and will gradually get deeper as the cut progresses. Normally for a simple cut, I start at the very end of the shaft by the TS so the bit digs in right away upon hitting the material. If you must start in the middle, it's common practice to use a groover and dig a starting point.
Were you using carbide or HSS-type cutting bits?
Watch out for swarf... overcome the urge to touch it or get near it when the machine is in motion -and that means wait till a dead stop. Many cut tendons (and worse) from machines smaller than yours.
Ray
Ray
OK, so just as a quick-and-dirty, I tried a couple of cuts yesterday.
The first, was on a .5" piece of stainless. Put in in the three-jaw, center-drilled the end and put that on a live center. I took a .015" cut for almost 5". I started about 2" from the live center. I noticed that near the live center, I was getting small(er) chips, and as I got within a couple of inches of the 3-jaw I started getting this long, golden colored chip that had the cutting fluid smoking a bit. Pulled the rod out and did a quick measurement with my calipers. There was just over a thou difference between the measurements (I measured about 3" from the live center end, and right near the chuck). Not bad at all. I figured from watching the chips that I was getting some part deflection.
Next was a piece of 6061, 5/8ths thick. Did a .025" cut for about 3" on the unsupported rod. Bright shiny cut that had this long chip wrap itself around the rod near the chuck. Have to watch that stuff, as I figure it can probably slice me up pretty good if I'm stupid enough to get my hands near it. After pulling the aluminum Brillo pad off the part, I pulled the rod out and measured it like I did the other. Less than a thou difference.
Good enough for now. I'm pretty happy so far.
