I've been very interested in your rebuild since I have just recently bought a heavy 10 199z with a 3.5' bed. I am interested in how you removed the old paint and what kind you used to repaint, nice job by the way especially considering your situation.
You just used stripper then, did you have to use any filler for the pitting in the castings or didn't the pits show after stripping? It sounds like you sprayed all your paint and didnt brush any.My technique is nothing special, just a heaping helping of elbow grease. I used paint stripper, the good stuff that smells real bad, and burns if you get it on your skin. Of course I soaked most of the parts in simple green for a day or so before the crud would come off.
After they were clean and stripped, I wiped everything down with denatured alcohol, taped off machine surfaces, applied rust-oleum clean metal primer, set 24 hrs, then 2-3 coats of gloss smoke gray, in a rattle can for most of the small stuff. I'll use a spray gun for the larger pieces, and I toyed with the idea of having the really big pieces sandblasted, but the stripper works well, and is cheap, and on my schedule.
-Cody
Cody, how's the lathe coming? I'm getting back around to finishing up my H10 restore and set-up after so many starts/stops. I know how it goes with finding the time to get all the things you -want- to do done.
WHOH Splat! It's been a while... Glad to here you are still chipping away there! Keep your eyes peeled for the NJ Machinists thread- we're going to attempt a get together next month sometime
