- Jul 5, 2014
- 2,776
I've got a 22.5 cfm 7.5hp 220v single phase two stage compressor. Ran it yesterday for 6-8 hours and zero problems. Today it won't start.
I'm not too good with electrical. I can run wires, add a circuit, install a phase converter (with help) check voltages.
It has a mag starter on it. I've checked incoming voltage all the way from the breaker to the compressor. Seems fine. The pressure switch is closed, power to and out of it.
The mag started doesn't engage. I can manually push it in and get voltage to both legs of the motor but no go. Even tried putting voltage directly to the motor bypassing the mag stared and still nothing.
Thankfully I have a backup compressor, but it's half the cfm and my pressure blast cabinet keeps it running constantly.
I've found a replacement motor for $535 with free shipping which isn't bad, but before I buy it I want to make sure I'm not missing something.
HELP!!!
HELP!!!
