- Apr 30, 2015
- 11,305
Yep it's a "permanent split cap" also called a capacitor run motor. I believe John is correct you wire the cap betw. yellow and either red or blue, the power goes to red and blue.
You may not be able to find that exact cap value, get the closest value in microfarads you can, a little more is ok. Cap voltage rating should be 165 v ac or higher. Must be a motor run type cap (oil filled)
Mark S.
Mark S.
