  • Guest,  We want to wish You and Your Family a Healthy, Happy Thanksgiving! Click the "X" at the top right corner to remove this notice)
4
Motor re-purposing - Proper wiring
3
Like what you see?
10
middle.road
Active Member
Apr 28, 2014
707
Likes
230
#1
I need some assistance in properly wiring up this motor. I am thinking of setting it up as a 'Foredom' type tool.
I've got a few hand pieces and am hoping I can get one to work for polishing wheels.
The motor has been kicking around for over 20 years, and I even forgot I had until I was unpacking an old box of clutter.
Firing it up 'as-is', it spins up nicely. However there seems to be a 50-50 chance of which direction the shaft will rotate. The labeling states CCW but it is going in both directions.
I figure that I need a capacitor or something a bit more than just an extension cord spliced to it. :grin:
Thanks!
strantor
Active Member
Oct 29, 2012
512
Likes
216
#3
it is definitely supposed to have a cap. Nameplate picture is hard to read, but there is a cap value given.
middle.road
Active Member
Apr 28, 2014
707
Likes
230
#4
Thanks, I'll go grab a better pict. Didn't realize there is no zooming in on pictures...
middle.road
Active Member
Apr 28, 2014
707
Likes
230
#5
Thanks Gang!
General Electric
Model 5KCP19PG190A
HP 1/2 RPM 3350
A 5.1 HZ 60 PH 1 EJU
Time Rating CONT Class B Code C
Cap 17.5 MFD ROT CCW Made in the U.S.A.
jim18655
H-M Supporter-Premium Member
Nov 23, 2013
512
Likes
361
#7
No cap would cause the random rotation direction. There should be a capacitor housing or look like a place for one.
middle.road
Active Member
Apr 28, 2014
707
Likes
230
#8
Peeled back the shrink-tubing (I want some of that style, pretty tough stuff...)
There's a Blue, a Red, and a Yellow coming out of the housing.
The yellow was taped off.
No sign of a capacitor housing on the motor anywhere. It is rather small, only 6" long.
jim18655
Nov 23, 2013
512
Likes
361
#9
Might have come out of an HVAC application. Some of those use a remote capacitor mounted in the cabinet or strapped on the side of the motor. Yellow wire probably was connected to the cap with power to the cap from the control panel.
hman
Feb 17, 2013
1,531
Likes
1,045
#10
My first guess would be to wire the specified cap to the yellow wire and to either the blue or red wire. To reverse rotation, move the cap to the other (blue or red) wire. But I might well be wrong ... not sure why the nameplate would specify a direction.
markba633csi
Active Member
Active Member
Apr 30, 2015
1,327
Likes
539
#11
Yep it's a "permanent split cap" also called a capacitor run motor. I believe John is correct you wire the cap betw. yellow and either red or blue, the power goes to red and blue.
You may not be able to find that exact cap value, get the closest value in microfarads you can, a little more is ok. Cap voltage rating should be 165 v ac or higher. Must be a motor run type cap (oil filled)
Mark S.
CluelessNewB
Active Resistor
Mar 3, 2013
982
Likes
425
#12
I believe that is a "Permanent Split Capacitor Motor", typically used for fans and blowers. The missing capacitor should be a RUN capacitor not a starting capacitor. Sorry can't help with the wire colors. I suspect the motor is marked for a single direction of rotation because of an internal cooling fan that works better that way.
Ulma Doctor
Infinitely Curious
Active Member
Feb 2, 2013
4,298
Likes
3,495
#13
the run cap is specified for 17.5 microfarads.
i'd try to get one very close without going under the microfarad rating.
you'll also need an oil filled capacitor for longevity of operation.
the run cap is part of the motor operating circuit, meaning that the motor will not operate correctly without the run cap in series with the windings .
without a run cap, the motor may overheat quickly and you will not develop full nameplate RPM or HP.
if you get a cap that is too much greater than 17.5 Uf, (25Uf or more) the motor may also run hot and may not perform to nameplate specifications
if you were to get a run cap much below 17.5 Uf, the motor may operate sluggishly, draw more current to run, overheat, and or not perform to nameplate specifications
if you have any trouble finding a suitable capacitor, i can help out
shoot me a PM, i'll get you straight. :)
middle.road
Active Member
Apr 28, 2014
707
Likes
230
#14
Thanks Gang! Time to start scrounging for a Cap.
Looking at images on a search they look to be about a 1/4 of the size of the motor itself - hehe.
middle.road
Active Member
Apr 28, 2014
707
Likes
230
#16
And, at the Estate Sale / Auction this past weekend there were many laying around.
The owner had an HVAC biz, and I didn't pay any attention or give any thought to grabbing a few...
(where's that 'head smacking icon'?):bang head:
middle.road
Active Member
Apr 28, 2014
707
Likes
230
#17
Scrounging this afternoon, all I came up with is 50uf 'starter' out of an old craftsman garage door opener.
Then thought a big ol' 1/2 hp Century might yield something - nope, got the cover off and the cap was gone.
I could have sworn I had a box of some laying around somewhere. . .
[6]
5 [7]
