Morse taper 1 tap follower plans
Do you have a tail stock chuck? Unless you want to play with the taper, you can make the shank cylindrical, and use the chuck.
i want to try and cut a taper because I have a second operation hardinge lathe. I have to set the taper and I want to try it.
Maybe consider adding a through hole so you can punch out the ram and bushing if you ever want to remove them.
I think I want to drill and tap holes for set screws to hold in the bushing. I'm grounded from the lathe for a couple of days so keep giving me ideas on what to do.
I would suggest a shorter stickout of the tap guide. When full compressed, the point should just engage the tap wrench. One of the shortcomings of commercial tap guides is the short travel. I would like to see .75" as a minimum. Rather than a press fit or set screws for your retainer, consider threading the retainer for easy removal for repair or servicing.
If you are startng with an existing taper, I would suggest using a MT1-JT33 adapter. It will give you an additional 1" of material to work with. If you are making your own taper, Just leave additional material on the taper.
I will make the taper long with extra material for more range. I don't have a 3/8 bottoming tap though. if I did I would thread it.
I like the idea of using the taper-area for this, I know any lathe with an MT1 likely doesn't have the bed length to spare for a drill chuck!
For serviceability, I might suggest making the bushing thread-in instead of pressed in. That would give you the ability to pull it apart easy enough. Then just use a pair of holes for a spanner wrench or something (or, just have it protrude a 1/4" for flats).
it could have a morse taper 2. my wood lathe has a morse taper 2 and the ram is smaller than that on my metal lathe.
I'm guessing you missed some homework? Next will be parental block on this web site. Boundaries, limitations, and consequences :)
luckily I know more about machining and like machining than video games. only get grounded from wood and metal working if I get my phone and iPad taken away. they can only block it on my phone :grin:.
