- Nov 14, 2016
- 3,001
Yes, more than one lathe is useful. I have 3 an 11x24, a 9x20 and a little Sherline 3.5x17. The Sherline gets the most use of the 3 for the stuff I do.
Other than cutting metric threads the 9x20 is kind of redundant, but I got it more as a project. There are a ton of mods people make to the 9x20s, it was about 45 minutes away and the seller was offering it at a price hard to pass up. I thought it would make a good experimenting lathe.
I get the "you can do anything on a large lathe that you can do on a small lathe" thing, but if you don't need the size changing tooling on the Sherline is a lot easier as most everything weighs less than 5lbs. The whole lathe weighs about the same as a 6" 3 jaw chuck. Smaller tooling can also be considerably cheaper. Of course the reason I have a bigger lathe is not all of my projects fit onto a 3.5" swing lathe.
