Mini Mills-HF or Grizzly or ?
I was going to do the x2 from harbor. Had it ordered and they were jerking me around so I got the wife to let me have some extra funds and went with a g0704 from grizzly. I know for a fact the x2 would have been a let down just because of table size and such. Liking the grizzly for now. Just remember they are light duty hobby machines. I use all snap on and such at work also. Bridge ports and Logan's and such for machine tools. It's hard to come home and not be able to throw a 2" block of stainless on the table.
yes if you can afford it i believe the G0704 would be a little better machine. It is heavier however. Some have mentioned the G0727 which in my mind is a great looking machine but completely different type of operation. for general light work i would rather have the HF mini over the G0727. Then for other types, arbor driven tools, get the G0727.
My first mini-mill a decade ago was a tilt column. Not bad, depending on what you want to do, but my LMS solid column is much more rigid and the belt drive much smoother and quieter. No hi-lo speed changes either. I also wanted the inch leadscrews.
Bill
Thanks for all the help.
I ordered the HF 44991. I know there are better tools out there but I wanted to get started and have some $ left for tooling. The mill has an R8 spindle so most should transfer over to a better machine if and when.
Good for you! Pics when you get it!!
Bernie
nice choice in my humble opinion. give me a PM for details on the mods i mentioned in the past posts.
Got the little mill moved into my cluttered garage. Still have to bolt it down and finish the set up.
If you have the funds, get the belt drive from LMS, you will not be sorry. I ran mine until I stripped the gears and after putting the belt drive on I wish I would have done it from the start. Quieter, smoother and an all around better feel. Never thought it would make this much difference.
The belt drive is on the list. A member here shared his mods to the mill, air spring and reverse switch. Those will be my first additions. After the holidays a belt drive and a better vise.
Made a chip pan out of alum panels, used on trailers. Made to be removable. Post a pic in a few.
