- Jun 12, 2014
- 4,810
Probably not the right forum for this question, but it is relative I believe; What would you gentlemen recommend a new guy with a new(to him) lathe to practice first? Is there any recommended order of things to do first?
I concur with 3dshooter80, you can either do a lot of damage to the lathe, or yourself, so getting familiar with the controls and getting some learned reflexes is a starting point. Each material and project uses different skills. It is also important to understand the accessories and tooling for these machines, how they are setup and how they are used. One can ask questions if one is unsure, review what others recommend, and then decide what works best for you.
As far as the sequence, start with the basics in easily machined materials such as aluminum an mild steel. Learn how to face and size material first, then center boring/drilling, and then threading/more technical turning. One nice source of YouTube information that starts with the basics and then advances into more technical turning was the MIT Essential Machining Skills: Working with a Lathe. I also found this and reading some of the South Bend Lathe training materials to be very helpful in explaining how the lathe works and the reasoning for machining a particular way. I always learn from others, so I watch how they do machining and then ask questions if I am unclear or I do something different. I am always learning new things, and I greatly appreciate the information exchange.
I am a bit disappointed that site moderators do not restore wholesale deletion of posts like this thread and a few others that were inappropriately and completely deleted. I think there is important information to be learned by others, and the information provided was reasonable and factual. This is one of the forum rules, and by posting in this forum, one agrees that the information is not deleted because one gets mad or frustrated. It is very reasonable to make corrections or clarify content after the matter of the fact, but I find that valuable learning information should be maintained when appropriate.
