- Apr 24, 2021
- 462
Awesome, thank you.The borax just keeps the steel from oxidizing and pitting when you do your heat treat. As far as I know, it plays no other role in metallurgy. Removing stock with a regular drill and finishing the profile with a D-bit will make it easier when you are going for a flat bottom, but no pilot hole is needed for a D-bit if you grind a relief on the bottom edge from center on the non-cutting side. Just extend the 30 degree relief in the diagram below all the way to the center and it will plunge and leave a flat bottom. For more info, read the attached Deckel manual for a brief, or check some of the texts like Moltrecht if you have a copy, or the Workshop Practice series available on our H-M download library.
