- Jun 7, 2013
- 10,133
It may not have had enough clearance, also should have a second clearance angle, and the margin could be split or thinned, in other words, it should look more like an end mill point.
I wish I knew more about hardening. I don’t have any special equipment. Just a blow torch for my hardening endeavors.You can make a flat bottom drill from an old drill bit. 4140 is not an appropriate steel for making cutting tools. It is more suitable for mandrels, blocks, screwdrivers, wrenches, pry bars, etc. If you have some Kasenit or old fashioned pack hardening equipment, you could try to case harden the 4140. In a pinch, you can use iron wire and boric acid with a torch and get it screaming hard (that's as hard as it will go without grain growth or decarb) with no drawing temper. It will cut...for a while.
Ok, I’ll give it another go. I figured the drill rod D bit would work better and make a nicer hole, but I guess it’s my grinding skills. Anyone have a modded drill bit handy to snap a pic of?It may not have had enough clearance, also should have a second clearance angle, and the margin could be split or thinned, in other words, it should look more like an end mill point.
No a drill bit ground to drill flat bottom holes. 5/8 is the diameter. Are you saying I should use an end mill? I have drill stock I can get for super cheap. I can’t afford to buy anything right now. The drill stock, or old drill bit I have laying around. I can get those for a dollar, or two.What diameter, center cutting end mill?
I initially was going to do that, but I just paid for my fall classes.I use center cutting end mills if I have them for shallow flat bottom holes.
