- Dec 21, 2018
- 1,826
Even a "center cutting" end mill doesn't plunge cut really freely. There is no relative motion at the center. Difficult for them to clear the chips. Your drill bit grind didn't have any cutting edges near the center! A D bit grind has the advantage of lots of chip clearance. It would be pretty difficult to hand grind a D bit so the split was dead center.
If your project will permit, drill a small shallow hole in the center, slightly deeper the the final flat. Then use a drill bit that you have flattened and relieved to form cutting edges.
