- Dec 18, 2019
- 6,464
You need to try this. It's a valuable skill to learn. Try it on some cheap PVC pipe to start. You can buy some 1/2" pipe for very little cash. It's not hard to figure out the gears. Pick a thread to try, and see if you actually get it. If you have a thread gauge, great. If not, choose a thread that you have a screw, that way you can use the screw as a thread gauge. Try to pick a finer pitch and a very slow RPM to start. It's easier to learn the basic timing that way.I have not threaded on the lathe yet. I did not have an Imperial tap suitable for the jack body, and didn’t want to figure out change gears. Need to dip my toe into that water…
