- Oct 16, 2019
- 6,596
Right, that makes total sense.There are several(usually) gears between the spindle and the lead screw. As long as they run in the same plane, they are only idlers. The only control they offer is changing direction based on an even/odd number. A stepped gear is where two gears are keyed together, say a 60 and a 40. Driving the 60 into the 40 would reduce the output by a small precentage. My mind says 33%, but, like I said, I'm slow tonight. Basically, the same as a drill press, where the smaller the driveing(power) pulley and larger the driven(load) pulley, the slower the spindle runs.
I have a fairly tight range of TPI options in the coarse range:
4
4.5
5
5.5
5.75
6
6.5
One of those has to get me in the ballpark
