Leveling my lathe
Pevehouse
Oct 27, 2023
383
I’m noticing that even after I leveled my lathe, it’s cutting a little bit of a taper. Was wondering if I may have set my level on the wrong part of my bed. My ways are in the picture. Where should I place my level on these kind of ways?
-- Did you first align your headstock to the ways?
Don't forget the tailstock to headstock alignment. Moving the tailstock laterally is one way to get a taper, and many do that intentionally.
Sent from my SM-T500 using Tapatalk
I will check the tail stock alignment. Not sure if the headstock can be aligned to the ways on my machine. I have heard of putting the level on the cross slide but wasn’t sure if that was accurate or not. I appreciate all the input
the method that I use is to level the bed by placing the level on the carriage or cross slide. Then do a two collar test. Then align the headstock to remove any taper.
I will have to see if I can find that information
