- Apr 23, 2018
- 6,550
Nice job with the pics, the views from the side of the cutting edges are very clear.
I don't think the little kick up on the outer edge of the bit is an issue. It looks like it comes from the flute profile, not from the grind. You've already proven it's not a problem with testing!
Remember, the stickout defines the radius of the cylinder swept, so less stickout means a tighter sweep and a higher relief angle. It seems like the set point in the instructions for your jig gives a good result.
In the photo of the ground bit from the front, you can see ever so slightly that the cutting lip rolls off and that the cutting edges are bowed. This indicates that the clocking/indexing of the flutes needs a slight adjustment to bring the cutting edge straight and avoid that roll off.
A little bit of fine tuning, and you'll be re-grinding factory sharpened bits because you know you can do better than mass production can!
