- Jan 25, 2022
- 110
Agree this is probably splitting hairs but an idle mind rattling around:
Say I have a RH HSS turning tool with a side rake (say, 12 degrees), minimal back rake.
A nose radius of 1/32" so the tip of the tool is slightly lower than the leading edge.
Then where the tool engages the work relative to work centerline will depend on the DOC. Where should I set my tool height - to the leading edge?
More generally, is it better to err lower or higher when setting tool height?
Thanks
Thanks
